Creaking/Popping noise while turning
Old 05-14-2018, 01:12 PM
12ElantraGLS's Avatar
Default Creaking/Popping noise while turning
Hello all,
My 2012 Elantra GLS (6spd man) has developed a creaking/popping noise from the front end. It is usually only noticeable at low speeds when the steering wheel is turned more than 1/4 or so (like when parking or turning at an intersection). Appyling the brakes while turning makes the noise worse. Straight line braking/accelerating does not produce the noise. Turning the steering wheel while parked does not produce the noise. Bouncing the suspension while parked does not produce the noise.
I had the car up on jack stands recently trying to replicate the noise and only found one thing that made a similar noise. With the front wheels in the air and the trans in gear, there was a bit of free play at the wheels. I was able to rotate the wheels a couple of degrees without resistance and then when the other wheel started to turn there was a creaking noise that was very similar to the noise I'm hearing while driving. Everything looks ok (all CV boots are intact, no evidence of leaking lube from any boots or bushings, very little underbody rust).
Any thoughts?
Old 07-20-2018, 05:19 PM
Pitar's Avatar
Sounds like the trans axle CVC joints are worn.
Old 07-29-2018, 09:36 AM
avisitor's Avatar
Does the noise only happen while in motion and turning in one direction?
Old 07-31-2018, 02:23 PM
nickc29's Avatar
Did you ever find out what was wrong? Was curious about the trans axle CVC joints as well
Old 05-24-2019, 11:51 AM
SBA's Avatar
SBA
SBA is offline
Similar issue with my 2011 Elantra - do you hear any sound when driving fast ? In my case it was a bad wheel bearing for front passenger side . Costed $$$$$$ to fix
CAW
06-12-2012 03:54 PM
CoolElantra
10-02-2010 04:29 PM
hoffy5
07-19-2010 06:44 AM
Rdturbulence
07-10-2008 12:39 PM
misstibs
01-03-2005 11:40 PM
Quick Reply: Creaking/Popping noise while turning
