2013 Elantra Interior lights come on with slight door pressure.
Old 05-19-2019, 03:51 PM
TheNumerous1's Avatar
Default 2013 Elantra Interior lights come on with slight door pressure.
Just like the title says, if I put slight pressure on the drivers side door, such as when I’m coming around a turn and lean into the door, the interior lights come on and the door ajar light comes on. Any idea what’s causing this?
Old 05-19-2019, 05:13 PM
If you can duplicate the problem with the vehicle parked and just pulling on the door, you are halfway there. Now all you need to do is remove the interior door panel and watch what moves and go from there. There could be some other reason , but since leaning on the door has that effect I would be inclined to start there..
Old 05-19-2019, 05:15 PM
It definitely does it when parked. Will pull the door panel off and see how it goes.
andrew1234
02-28-2017 10:43 AM
jlsw
04-06-2016 10:17 AM
Florida_Orange
07-10-2014 07:40 PM
achilliz
04-29-2013 07:24 AM
frankcabanski
04-02-2011 10:26 AM
Quick Reply: 2013 Elantra Interior lights come on with slight door pressure.
