Dashboard lights went out 2002 elantra
My daughters dashboard lights went out after she plugged her gps into her lighter. I found and replaced a 10 amp fuse that was blown labelled c/lighter but her lights still do not work and the fuse is still good. Any ideas what else i should try?
Did you check the other fuses? sounds like a short
all the other fuses are good
Checked the other lights and noticed right tail light was also out. checked that fuse and it was also blown. replaced fuse and now all is working again.
