Driver side master power window switch
Hi I have a 2020 Hyundai Elantra Special Value Edition and my driver side window switch went bad and I just want to know if you got to remove the door panel to replace the switch or does the switch just pop out of the console and does anyone have any videos on how to do it
If the master sw is on the driver's side door, most times the sw assy can be carefully lifted up and pulled out to replace or do some checking.
If you don't have the finesse and patience for this, best to leave it to a shop that does this type work. |
Originally Posted by Jcthelight1976
(Post 65932)
Just because the window doesn't go up or down when you operate the switch does not mean the switch is defective.
Checks for power and ground should be done to verify they are available or the problem will still be there after switch replacement. |
| All times are GMT -5. The time now is 03:40 AM. |
