Driver's side mirror popped out of housing
I ran my car through a carwash a couple of days ago and as it came out, the driver's side mirror popped out of the back plate. It will pop back in but is really loose and will fall after a while. Wondering if this is possible to adhere back on and how to do so or figure out if I should just get another mirror. This is an issue with the 2012 Elantra is what I was told
Peice still inside mirror shell
Back of the mirror, glass is still in tact
Look at the center piece of mirror, it is broken and missing a piece that holds it
On the mirror itself you have two white studs that go into the two holes
They are meant to be just tight enough to move the mirror but let loose when pushed
So when someone is pushing the button for too long it won't just break
This is why it will come off after a little while
It is the center piece that broke off that hold the mirror tight together
I unfortunately ended up having to order the part from the manufacturer and replacing it myself. The piece holding my mirror was too broken to just fix
Which part?
