Heated 02 sensor help
Old Aug 10, 2010 | 08:48 AM
Benjamin's Avatar
Default Heated 02 sensor help
I have an '05 Elantra and I need to replace the 02 Sensor, B1S1, due to faults P0030 and P2237. I know what it looks like and where it is. This is not my problem. My problem is that I search online and I find websites that list different sensors with different connectors, attached and not, as replacements for mine. It should be noted that I have not yet been able to disconnect mine to get a good look at the connector. If I use Autozone as a reference, then I can choose between Bosch p/n's 13565 and 15733. If I go to Thepartsbin.com, they have them both plus a few others. Which one should I get? The 13565, the 15733, or a different one?
Old Aug 10, 2010 | 05:49 PM
Buy neither of them,,,, you need to visit the dealer and buy the factory part, which I will venture yours has a wide "D" shape snap release connector with 5 or 6 wire in it.... it is a special style sensor, not a 2 wire feed with 2 more for heater as seen in your part numbers posted..
Old Aug 11, 2010 | 06:36 AM
Benjamin's Avatar
I took a look at the connector yesterday. It's either a Denso 234-5430 or a Walker 250-25012, but I'm thinking it's the Denso model because it has four wires and mine has four wires while the Walker has five.
razorback trans
Feb 12, 2009 08:25 AM
Fro
Jan 21, 2009 05:09 AM
nevis111
Jul 3, 2008 03:30 PM
racer14k
Jan 1, 2008 11:51 PM
Islandbound
Dec 31, 2007 08:01 PM
