heater blower not working
Old Dec 6, 2008 | 11:15 PM
messybarnyard's Avatar
Default heater blower not working
I have a 2000 Hyundai Elantra and the heater blower quit working. Could it be the relay or the resistor? I don't know where the resistor is located. When I turn the blower speed ****, I can hear the relay click and it sounds like the compressor is engaging. Or is it the actual blower motor that died? Any help or info would be greatly appreciated. Thanks in advance.
Old Dec 11, 2008 | 12:51 AM
freude09's Avatar
Default RE: heater blower not working
looks like the motor itself has the problem, better check the motor and the pipes...
Old Dec 11, 2008 | 07:06 AM
ORIGINAL: messybarnyard
The resistor is only for fan speeds 1 thru 3. The 4th setting does not go through the resistor so if the fan doesn't work on any setting and you can heat the relay click, I'd check the blower motor itself.
renfrance
Mar 26, 2020 12:14 PM
IndianaMitch
Dec 23, 2011 09:48 PM
rcht5
Feb 23, 2011 06:33 PM
abaird1
Oct 1, 2008 09:46 AM
barking
Sep 23, 2007 12:53 AM
