Hyndai 2011 Elantra Gls - Defogging Logic & A/C Issue
Hello,
First time posting so I apologize if this may be somewhat of a duplicate item: First of all, I am confused by the defogging logic. What is it's purpose? I have a manual climate control syatem & the owner's manual gives instruction on how to turn it off or return to the programmed status: Manual Climate control System: Press the defrost button Push the air intake control button at least 5 times The indicator light in the air intake control button will blink 3 times with 0.5 second of interval. It indicates that the defogging logic is cancelled or returned to the programed status. This last sentence seems contradictory. First, how do I know if the defogging logic is cancelled or is on? 2nd, when want to defog the windshield and press the front defrost button the a/c light comes on. I then played with the defogging logic and now when I press the defrost button the a/c light doesn't come on. Does this mean the defogging logic is cancelled? Please advise on these two issues as they are confusing. Sincerely, John (Sockers 52) |
Originally Posted by sockers52
(Post 37445)
(Post 37445)
(Post 37445)
(Post 37445)
Defogging Logic - Follow-up question
Hello,
Just to claify a few things: I understand that when you press the front defrost button and the A/C light comes on then the defogging logic is on as well. What is the purpose of defogging logic when it is on? What happens when you press the button right above the recirculate button as shown in the following photograph when defogging logic is on? That is a defog button as well. I would assume the A/C light will come on. Is this correct? http://autocarsprices.com/wp-content...ncept.com_.jpg Thanks, John |
(Post 37454)
What happens when you press the button right above the recirculate button as shown in the following photograph when defogging logic is on? That is a defog button as well. I would assume the A/C light will come on. Is this correct? http://autocarsprices.com/wp-content...ncept.com_.jpg |
