Map sensor on 05 elantra.
I need help, where is the MAP sensor on a 2005 elantra (XD) 2.0 eng, I can not find one no where. A pic of location will be great help
RE: Map sensor on 05 elantra.
I need help, where is the MAP sensor on a 2005 elantra (XD) 2.0 eng, I can not find one no where http://www.hmaservice.com/data/Passe...G/efke301z.gif |
Thanks Ken. I am wanting to add a hydrogen generator unit to it, and the MAP sensor was one the sensors that had to be manipulated, also the O2. The MAF also can be manipulated instead of MAP but MAP was better if had one. maybe you could help me as to what would be the signal wire on the 02, and is the MAF frequency based signal or voltage?
The information you seek can be found on http://www.hmaservice.com/. You have to use IE, register for a free account and download some viewers (which you may already have). Look under the "Shop" or "ETM" options. The above graphic was found on this site. Come back here if you have trouble finding what you are looking for. Also, there is a similar site for Kia that seems easier to navigate with the same basic information, but in this case you would look up a 2005 or 2006 Spectre, http://www.kiatechinfo.com/index.asp
I spent about 45 min in this site, I am already registered there, I did find schematics, but they was basic schematics, and did not show nothing about which wire was what on either O2 or MAF, basically showed about where they were.
Here is the wiring schematic for the MAF and both O2 sensors. Shows the wire color and connector number including the master bus.
[IMG]local://upfiles/4972/18131D123F24469E9E582DCFC8628581.jpg[/IMG] |
I searched all over the site for that, never could get it! how did you find it! Is there also other sites to get info on gm autos? |
| All times are GMT -5. The time now is 07:03 AM. |
