Need help so bad
I have experiencing a lot of problem on my 2001 elantra. But i guess it was time to change a lot of stuff after 176500miles. i got it from my sister, she never did any major maintenance , from breaks to belts, all she was doing is oil change. well i fix pretty much every thing cost me $2200. But i still have three problems, This morning my radiator blow off (a crack line going across, i dont know what coz a radiator to do that, i just ordered new one for $194, but i'm wondering if there is another issue i need to take care off. second is oil leak, somewhere close to the themostart i see some bolts sticking out a little bit, my third prob is low beam light, the keep on blow off every two months, i make sure i dont touch the class part, but i still have the same problem
RE: Need help so bad
[align=left]Radiators are cheap plastic now, expect to replace them sometime in the life of the car, unless you're like me and get out your fiberglass repair kit and fix it yourself.
Sometimes you have to take things apart and investigate, I'm sure your oil leak is not serious. Can't help you with the lowbeam, it's a short someplace, but where you won't know until somebody tracks it down. |
