no air flow control - 2008 elantra
purchased used 6 months ago. 58,000 mi. awesome car, btw.
always had an air-flow funk, most notably a 'clicking' in the dash on passenger side that was related to which air-flow selection was chosen. nothing made much sense - it would mostly click all the time and the airflow would change around somewhat but generally maintained control over defrost - dash - feet, etc. but now, just when i need defrost, there is NO change in air-flow - everything comes out of the middle regardless of selection. and there is no clicking. i've seen reference to vacuum, air-flow blender, various things. looking for some good insight, and i appreciate any response. learned how to get by (barely) by turning on fan to high and manually closing the dash vents - this forces a little warm air up through the defrost vents. thanks again! |
Did you happen to find a solution to the air-flow control problem ? I have the same problem with my 2003 Elantra. The rotary switch turns just fine but doesn't change the direction of air-flow.
| All times are GMT -5. The time now is 01:02 AM. |
