OBD2 live data Reading HELP?
2005 elantra
dtc-cnt 0 fuelsys1 cl fuelsys2 n/a load % 16.9 etc 108 shrtft1% -3.9 longft% 3.9 rpm 1174 mph 0.0 sparkadv 15 iat 17 maf .557 tp 6.3 o2b1s2(v) .410 eq_ratb1s1 .987 o2b1s1(v) 1.981 |
Originally Posted by dadam
(Post 32713)
2005 elantra
dtc-cnt 0 ----------------------> No DTC fuelsys1 cl ---------------------> Closed Loop Bank 1 fuelsys2 n/a -------------------> Bank 2 N/A... it a 4cylinder load % 16.9 --------------------> Calculated Engine Load etc 108 ------------------------> Coolant Temperature shrtft1% -3.9 ------------------> Short Term Fuel Trim longft% 3.9 --------------------> Long Term Fuel Trim rpm 1174 -----------------------> RPM (engine speed) mph 0.0 ------------------------> Vehicle speed sparkadv 15 --------------------> Spark Timing iat 17 --------------------------> Intake Air Temp maf .557 -----------------------> Voltage to PCM (Mass Airflow value) tp 6.3 --------------------------> Throttle percentage value o2b1s2(v) .410 ------------------> Ox Sensor, post catalyst eq_ratb1s1 .987 -----------------> Dont recognize this one o2b1s1(v) 1.981 -----------------> Air Fuel Ratio Sensor (tell by voltage value, std ox sensor operates .1 - 1.0v) |
Can you tell me what the readings mean?
ok yes
