p0335, crankshaft position sensor help
Hi, this problem is occuring on a 2007 Elantra GLS; we're throwing code p0335 - the car has trouble starting, but it idles just fine, and operates fine under load up to 2500 rpm. After 2500, usually around 27-2800rpm it starts balking and throwing major hissy fits. No power, engine lopes, just really not fun to drive at all. :)
We've done a complete tune-up on every other area of the car to make sure as we go down the list trying to fix this, nothing simple has been overlooked (so once we clear the code everything else is up to par at the same time). There's 30k miles on it right now, and I'm hoping replacing the sensor will fix it, but I'm slightly worried that it may not be that simple. Has anybody else ran into this, and what experience did you have with it? Oh, and I tried asking this on another Hyundai forum, and the general consensus was 'um, why not take it to a mechanic?'. I live just under 200 miles east of Vegas, in the desert. There is no Hyundai certified mechanic out here, and driving the car at 20mph into the city is out of the question. If we can, we need to fix it ourselves, so any and all help is greatly appreciated. |
Replace the sensor...
The symptoms you describe are consistent with a failing crankshaft rotation sensor, but 30K is much earlier than for one of these to go bad than I've typically seen. It could be tooling around in the desert heat has hasten it's demise. At this mileage, this should be a warrenty repair at the dealership, but like you say, a 400 mile round trip may be more hassle than it's worth.
This is a relatively easy remove and replace procedure. If you are buying an aftermarket sensor (which I assume), make sure the gasket (or rubber o-ring) and the mounting bolt match the ones on the original sensor. This sensor is used in several application and the required bolt length can be different, but some aftermarket kits provide only one "standard" bolt which may work right or may not. Use the old bolt if they do not match. Also, sometimes the o-ring gasket will stay stuck in the mounting hole and will keep the new sensor from extending all the way into the hole. The engine may not start or will run like it has a bad sensor. Make sure the hole is clear of any obstructions before inserting the new sensor. Detailed instructions for making this repair are at http://www.hmaservice.com. Good luck. |
Much appreciated, Ken. We've already got one on order from Napa, SMP #PC528, same as the one coming out.
Quick question, I pulled it out earlier just to make a visual inspection that there was no physical damage to the harness, connector or unit itself and there was no o-ring on the sensor or in the mounting hole whatsoever. Could that be a factory oops? |
Originally Posted by mwaterous
(Post 25227)
Quick question, I pulled it out earlier just to make a visual inspection that there was no physical damage to the harness, connector or unit itself.
(Post 25227)
At 55, I don't remember as well either. I would simple make sure what you stick back in the hole matches what you took out. I'll post back if a ring comes with the new sensor tomorrow. After you mentioned that I ran through my head a few dozen times whether or not it might have just fallen out and I didn't notice it. The CPS is tucked in there fairly snug after all. |
P0335
(Post 25220)
We've done a complete tune-up on every other area of the car to make sure as we go down the list trying to fix this, nothing simple has been overlooked (so once we clear the code everything else is up to par at the same time). There's 30k miles on it right now, and I'm hoping replacing the sensor will fix it, but I'm slightly worried that it may not be that simple. Has anybody else ran into this, and what experience did you have with it? Oh, and I tried asking this on another Hyundai forum, and the general consensus was 'um, why not take it to a mechanic?'. I live just under 200 miles east of Vegas, in the desert. There is no Hyundai certified mechanic out here, and driving the car at 20mph into the city is out of the question. If we can, we need to fix it ourselves, so any and all help is greatly appreciated. https://www.dreamlandmotorworks.com/...i-elantra.html |
| All times are GMT -5. The time now is 05:44 AM. |
