Plastic shield between wheel-well and engine
Does someone know how to remove the plastic shield between the wheel-well and the engine-space (right above the control arm, just ahead of the driveshaft).
It seems like its fasten in two points (upper part, the lower part is just loose) but I canīt see any fastening details. Its an 2001 Elantra... |
It ought to be the "grided" sheat in the upper left corner of this picture
http://www.hyundaitechinfo.com/data/...G/EIDA401C.gif |
2 bolts hold it to the frame rail... sometimes 3 on the older production.
Need a short 10mm socket and long extension works best |
