-   -   Primary Resistance on Coil ???????? (https://www.hyundaiforum.com/forum/hyundai-elantra-17/primary-resistance-coil-3607/)
AManiscalco2007 Jan 3, 2008 04:55 PM
Hey Experts,
I have another question for you. In my manual it is telling me that the primary windingsresistance in the coil should be 0.45 to 0.55 ohms. I tested it using a digital voltmeter on the 200 ohm setting and got 1.1 ohm on both. Does this mean that the coil is no good?
madindian1 Jan 3, 2008 10:31 PM
RE: Primary Resistance on Coil ????????
well is the car running? according to the specs. it would seem as if the coil is no good but i say if it's working that would tell me that the coil is good. sometimes those specs tell you what to look for when diagnosing a problem, if you had came up with a number like 2.5 ohms then you know you have a problem.
AManiscalco2007 Jan 5, 2008 07:26 AM
Yeah, it was runninhg but loping at idle and throughout driving. I visually inspected the coil pack after I removed it from the car. Looking in the plug posts on the coil pack I noticed that #1 cylinders's post internally was corroded very badly. The rest of them were fine.. I am just gonna replace the coil pack. Thanks.
