problem please help!
I have a 1998 Elantra sedan.
The red warning light that comes on when you raise theBrake is always on when I am driving. The brake is down and I do not understand why this light is activated.I would deeply appreciate any answers. Thank you Danny... |
RE: problem please help!
Assuming your back wheels are not getting hot when driving, it is probably the switchat fault, which is nothing to worry about, but is annoying.
thanks for the response chris!
no the wheels are not hot. the light on the dash just keeps coming on and off. once again thanks danny |
You need to check you brake fluid level, if is low this will happen. The reason it is flashing when you are driving means that is might be actually low so whenever the fluid moves around it activates the sensor in the resevoir.
| All times are GMT -5. The time now is 08:15 AM. |
