Bent my spare tire compartment
So, stupid me, I did a quick google search for where the lift points were on the back end of an Elantra, and I found a pic (this one) which I didn't read enough to know it wasn't even for the Elentra. Anyways, I put my floor jack under the shaded area in the back (where the spare tire sits) and lifted the car to do the rear brakes. Brakes are done, but not I realize I pushed part of the compartment up into my car!
1. Did I do any serious damage by this, other than a bent spare tire compartment?
2. Any relatively easy way to get it back in the correct shape?
I would say in all I raised the floor of the compartment by at least 3-5".
I'm an idiot.
I'm an idiot.
If you don't know how to jack up a car, how do you know what you are doing with the brakes ?????
Look, stuff happens! Don't beat on yourself.
I bet it can be pushed back down with a bit of geometry and leverage. I once pushed the trunk area of a Nissan Sentra back in shape using a few pieces of 2x4.
Cut a piece so you can place it inside and under the sides of the trunk like a cross bar. Cut another piece (push rod) so it fits between the floor and the first piece. Now you need a long 3rd piece as a lever. Put the end of the lever under the cross bar, put the push rod between the raised floor and the lever a few inches back from the cross bar. Now push the lever down slowly and carefully. If the sides of the trunk want to go up protect them with 2 x 4 pieces. You may need a piece of 2x6 or similar to distribute the pressure on the floor.
If it's a hatchback you will need longer pieces to wedge them under the roof edge.
Have fun with it!
By the way I always use wooden pieces to protect the car when I jack it up. They distribute the pressure.
Have fun with it!
