replacing seat belts how do you do it? 2002 elantra
[align=left]how do you replace seatbelts in a 2002 elantra..? dealer wants me to pay beaucoup bucks to replace driver side assembly..is it easy for the mechanically ignorant?:eek:
[/align] |
RE: replacing seat belts how do you do it? 2002 elantra
Yes, just simple bolts. You also have to take out some of the trim pieces, but I can help you out with that; I've done that before. I would recommend buying or borrowing a torque wrench and making sure the bolts are tightened to the proper torque. I bet most of the cost is the parts themselves. You'll save the labor money doing it yourself, but if you are buying new belts it's still going to be a significant expense.
Why do the belts need to be replaced? |
thank you for your rapid reply. one sunday morning the driver's side belt just stopped retracting. i know i am a big guy, but i've never had that problem before.
thanx |
There are two things you need to know if you want to do it yourself:
1. How to get the trim off to remove the belt. It's really easy and I can help you with that. 2. Make sure the bolts that hold the belt in are torqued properly; remember, your life may depend on it! Let me know if you need help with this. |
Originally Posted by Doohickie
(Post 8519)
1. How to get the trim off to remove the belt. It's really easy and I can help you with that. 2. Make sure the bolts that hold the belt in are torqued properly; remember, your life may depend on it! Let me know if you need help with this. Hey Doohickie, I found this thread about replacing the driver's side seat belt and was wondering if you could send me some info about how to. I have 2002 elantra. Thank you |
