Timing belt removal
Hello I am trying to get the crank pulley off so I can change my timing belt on my 1995 1.6 ltr dohc. I have removed the drivers side motor mount and the front motor mount and dropped the engine down some and it still will not come off. All the bolts are off and its just loose. I have tried pulling it out fromthe bottom but that still doesn't work. Is there a trick to this? The nut on the end of the crank seems to be in the way but I have no idea how this comes off or if it does come off. Please any help would be appreciated.
Thanks Budd |
RE: Timing belt removal
Dont know if this will help too much but here is a guide from the autozone website.
http://www.autozone.com/servlet/UiBr...3d801d6115.jsp |
Thanks titusrogers I went to that site. I did not realize that you had to remove the crank bolt. I didn't even know it was a bolt. thanks again
budd |
