Water Pump Belt
Could someone please give me a step by step procedure for changing the Water Pump/Power Steering Belt, and the Altenator belt. Thanks alot
Join here and get all that info and more (and it's free):
http://www.hmaservice.com http://www.hmaservice.com/data/Passe...G/edkb046a.gif Removal: 1.Drain the coolant and disconnect the coolant inlet pipe connection hose from the coolant pump. 2.Remove the drive belt and engine coolant pump pulley. 3.Remove the timing belt covers and the timing belt idler. 4.Remove the coolant pump mounting bolts, then remove the alternator brace. 5.Remove the coolant pump assembly from the cylinder block. Installation: 1.Clean the gasket surfaces of the coolant pump body and the cylinder block. 2.Install a new coolant pump gasket to the coolant pump and tighten the bolts to the specified torque. Tightening torque Coolant pump to cylinder block :20-27 Nm (200-270 kg.cm, 15-20 lb.ft) http://www.hmaservice.com/data/Passe...G/edkb050b.gif 3.Install the timing tensioner and timing belt. Adjust the timing belt tension. 4.Install the timing belt covers. 5.Install the coolant pump pulley and drive belt, and then adjust the belt tension. 6.Refill the system with clean coolant. 7.Run the engine and check for leaks. |
thanx, needed help on replacing my Mr Gasket Water Pump Belt too, the diagram was a great help since its hard to determine where what goes to.
