2010 Touring front "position" light bulb?
Old Aug 19, 2020 | 01:17 PM
bnsf97's Avatar
Default 2010 Touring front "position" light bulb?
Hi all,
I need to replace what the manual calls the front "position" lights, the ones that are below the high beam. I can't find any information on what bulbs these are supposed to be? I know the highbeams are H7 and lowbeams are H11B. Side marker lights are 168. Anyone know what the wattage or bulb type is for the position lights? Or have a good source for where I can find the information? I may just end up calling a local dealership parts department to ask. Thanks for any help! Autozone/OReilly etc databases aren't helpful.
Old Aug 20, 2020 | 06:55 AM
If you have the owner's manual, it will list the bulb specs in there.
Old Aug 20, 2020 | 08:54 AM
bnsf97's Avatar
Jeeze thank you. I was looking in the maintenance section where the instructions for changing the bulbs are and assumed it would be there. Forgot about the section after that on entire vehicle specs.
Old Oct 21, 2021 | 04:19 PM
mzb's Avatar
mzb
For some reason the Canadian version for the 2010 Elantra Touring manual only lists the bulb watts and not the bulb types
If anybody can post a photo of the page with the bulb types it would be appreciated. (Just had fun trying to replace a daytime running light... Possibly a.k.a Position Light. Not even mentioned on the Canadian Tire website )
Old Oct 23, 2021 | 02:59 PM
DrGEROH's Avatar
This from the 2010 Owner's Manual:
Front:
Low beam (outboard projector): H11B
High beam (inboard): H1
Position/parking/DRL (high beam reflector): 168/194
Front turn signal: 2357NA
Front side marker (bumper): 168/194
Front fog light: H27W/2 (881)
Rear:
Tail lights (x2, upper): 1157
Reverse (clear): 921
Rear turn signal: 1156NA
Brake/stop (lower): 1157
Rear side marker (bumper): 168/194
HTH --g
Last edited by DrGEROH; Dec 6, 2021 at 01:13 PM. Reason: Added front fog light spec
Old Oct 24, 2021 | 10:31 PM
mzb's Avatar
mzb
Thanks...
The Position bulb also gets called a daytime running light here to confuse everybody... Andy many websites don't list all the bulbs, so this information is invaluable.
Old Oct 24, 2021 | 11:24 PM
DrGEROH's Avatar
Our experience has been that the Sylvania 168 LED works well in all these positions, particularly the position/DRL lamp:
Amazon Amazon
Old Aug 22, 2022 | 12:30 PM
Caust's Avatar
I changed the headlight bulbs on my 2010 hyundai elantra to LED and they are way brighter then the stock bulbs, i highly recommend doing this upgrade. LED headlights are easy to find and relatively cheap to buy. For example, I can recommend the website https://carledheadlights.com/hyundai/elantra/2010/
jsolar
Jun 9, 2018 02:45 PM
daniel2229
Nov 4, 2013 07:27 AM
mn_dude
Mar 31, 2013 07:22 AM
watson58
Sep 6, 2010 10:35 AM
madmongodog
May 25, 2010 06:59 PM
