Elentra 2009 Stereo Removal.
Hi,
Just trying to install a new Stereo into my car that I just bought a week ago. I can't however figure out how to remove the radio. Thanks for your help in advance. |
>2009 > G 2.0 DOHC > Body Electrical System?>?Audio?>?Audio Unit?>?Repair proceduresRemoval1.Disconnect the negative (-) battery terminal.
2.Remove the crash pad center facia panel (A). (Refer to the Body group - Crash pad). http://www.hmaservice.com/data/Passe...shdbe6010l.gif 3.Remove the mounting bolts then remove the audio unit(A). http://www.hmaservice.com/data/Passe...shdbe6011d.gif 4.Remove the audio unit after disconnecting the audio connectors and cable(A). http://www.hmaservice.com/data/Passe...shdbe6012d.gif Installation1.Connect the audio unit connectors and cable. 2.Install the audio unit. 3.Install the crash pad center facia panel. 4.Check the audio system. This was off http://www.hmaservice.com/ so to install the head unit / stereo you will need to buy an aftermarket bracket/housing that will suit either double din or standard stereo. Usually install is simple from there here is the wiring diagram. This will show you negative and positive etc. Becarefull installing your deck as shorting it out negative to positive can cause it to blow instantly. No warranty LOL! >2009 > G 2.0 DOHC > Body Electrical System?>?Audio?>?Audio Unit?>?Components and Components LocationComponents http://www.hmaservice.com/data/Passe...shdbe9014n.gif http://www.hmaservice.com/data/Passe...shdbe9015n.gif http://www.hmaservice.com/data/Passe...shdbe9016n.gif http://www.hmaservice.com/data/Passe...shdbe6005l.gif Choose your deck enjoy! |
Does the crash pad just snap off?
On a similar note
so i tried to have my stereo professionally installed today and the problem that WE ran into was the availability of a dash kit.
we tried a BESTKIT dash kit rated for 2000-2007 and it was not the right size. did you end up finding a proper dash kit for this model (2009)? if so do you have a model number / website where i can buy one? any information would be very useful, as i have a 600$ double din currently sitting on the floor as opposed to mounted in my dash |
