i30 Stereo Removal
Old 06-19-2009, 10:39 PM
sr owna's Avatar
Default i30 Stereo Removal
>2009 > G 2.0 DOHC > Body Electrical System?>?Audio?>?Components and Components LocationComponent Location
1. Audio unit
2. Tweeter speaker
3. AUX Jack / USB Port
4. External amplifier
5. Front door speaker
6. Rear door speaker
7. Antenna feeder cable
8. Roof antenna (SDARS)
9. Feeder cable joint connector
※ SDARS : Satellite Digital Audio Radio Service
>2009 > G 2.0 DOHC > Body Electrical System?>?Audio?>?Audio Unit?>?Components and Components LocationComponents
>2009 > G 2.0 DOHC > Body Electrical System?>?Audio?>?Audio Unit?>?Repair proceduresInspection
CD changer operation instructions
- CD changer operation instructions may be somewhat different according to the CD changer model.
The following method is just one example.
1.Press and release LOAD button.
- Be sure to press LOAD to open the CD slot. If feeding a CD into the slot by force, it may cause damage to the CD changer.
2.After "WAIT" is displayed on the LCD, the CD slot will open with "LOAD" displayed on the LCD.
3.Insert a CD. The player will pull the disc in and begin to play automatically.
- CD can be inserted only while "LOAD" is blinking on the LCD and the CD slot indicator is flashing.
- CD must be inserted with the label facing upward.
- This CD player is suitable only for 12cm discs. DO NOT use irregular shaped CDs.
4.To insert multiple discs, press and hold LOAD button for more than 0.8 seconds. A beep sound will be heard and it will let you load CDs into all of the slots in which no CD has been loaded.
- This CD player takes up to 6 discs. DO NOT try to load more than six.
CD changer improper operation cases
If inserting a CD into the CD slot by force, the CD door behind the slot may be broken or separated from the head. It will cause the CD player not to work. Be sure to press LOAD button before inserting a CD.
CDs jammed in the CD player deck
DO NOT insert foreign substances like coins or tickets into the CD player. It may cause damage to the CD player.
Removal1.Disconnect the negative (-) battery terminal.
2.Remove the upper tray(A).
(Refer to the Body group - Crash pad).
3.Remove the crash pad center facia panel (A).
Take care not to scratch the crash pad and related parts.
4.Disconnect the connectors from the crash pad center facia panel.
5.Remove the mounting bolts then remove the audio unit(A).
6.Disconnect the audio connectors and cable(A).
External Amplifier
1.Remove the right side trunk trim and disconnecting the connector
(Refer to the Body group - Interiortrim).
2.Remove the external amplifier(A) after loosening the 3 nuts.
Installation1.Connect the audio unit connectors and cable.
2.Install the audio unit.
3.Install the crash pad center facia panel.
4.Install the upper tray.
5.Check the audio system.
? Make sure the audio head unit connectors are plugged in properly, and the antenna cable is connected properly.
External Amplifier
1.Install the external amplifier and connect the external amplifier connector.
2.Install the right side trunk trim.
Old 06-19-2009, 11:23 PM
lukepools's Avatar
how much power (watts) does the amp provide? Can you add on a bluetooth to sync up the new iphone or a HD radio to get the latest in radio?
Old 06-20-2009, 02:25 AM
sr owna's Avatar
Are the amp's the same as the us spec (im in australia)?
I believe there is only one version of amplifier for the i30 available thats oem.
On the slx and sr, the sr has a 6 stacker mp3 player and high quality speakers LOL. (which are hyundais own brand) But sound as good as my old $650 6.5" Jl splits.
As the slx only single disc mp3 but still has amplified speakers. I will investigate tomorrow and upload pics and info of our amps I don't know about the blue tooth tho..
>2009 > G 2.0 DOHC > Body Electrical System?>?Audio?>?Specifications
SpecificationAudio
Item
Specification
Model
RADIO/CD/MP3/XM
(PA710S)
RADIO/CDC/MP3/XM
(PA760S)
Power supply
DC 14.4V
Rated output
Max 43W x 4
Max. 2.5V
Antenna
80PF 75Ω
Tuning type
PLL SYNTHESIZED TUNING
Frequency range / Channel space
FM
87.5 ~ 107.9 MHz/200 KHz
AM
530 ~ 1710 KHz/10 KHz
Speaker
Item
Specification
Input Power
(W)
Front
Max. 50
Rear
Max. 50
Tweeter
Max. 40
Speaker Impedance
(Ω)
Front
4.0 ± 0.6
Rear
4.0 ± 0.6
Tweeter
3.4 ± 0.5
Speaker Number
External Amplifier
Item
Specification
Power Supply
DC 14.4V
Output Power (W)
180W (45×4CH)
LOAD Impedance (Ω)
I found this on the Hyundai Service Tech website
Old 06-21-2009, 07:06 AM
CSI007's Avatar
Wow,
Thank you. Looks like a standard double DIN unit but with non-standard mounting. Would take some work and some careful cutting of the front dash plastic to make an aftermarket navi fit in that.
Old 06-21-2009, 09:07 AM
lukepools's Avatar
Default amp
wow
with that, you could power a set of components at the front and forgo the rear speakers and bridge the amp for a sub.
I wonder what the SN ratio is and the THD is.
Luke
Old 06-28-2009, 09:33 PM
sr owna's Avatar
Im not that game to cut up my dash just yet lol!
Old 10-05-2009, 05:41 PM
juancarta's Avatar
Default auxiliar input for PA710 radio
Dear friends: I want to know how I can connect my MP3/MP4 to the auxiliar input in my TUCSON with PA710 head radio.
How can I connect to C2 + C3 connector?
Thanks for your help
Old 11-04-2009, 01:58 PM
bloggo's Avatar
Default i30 Bluetooth mute
Hi,
The stereo layout for the i30 was very interesting and appears to be from some sort of manual, if so can you advise where I could obtain a manual for an i30. My i30 is United Kingdom which I presume is the same.
My other question is about fitting a Parrot MKi9100 hands free kit and if the C1 pin 5 (mute) can be connected to the mute cable from the hands free kit and if this will stop the cd/usb from playing when bluetooth is in action. I have read on some vehicles that when the mute is used it displays either mute or phone when activated, does the i30 setup do this.
Old 10-31-2010, 09:10 AM
tmm_dk's Avatar
Hi there.
I know it's kinda late in this thread to post answers, but do any of you happen to know where there's a line-out signal to feed an external amplifier, from the standard radio in facelifted i30?
I'm not able to see any line-outs in the above schematics, and haven't been able to find any info by googling.
Thanks in advance.
Regards
Martin
Old 11-17-2010, 12:31 PM
teglasia's Avatar
Default dash pad remove
hi there!
I found this helpful post about stereo removal. My i30 has a bit different dash. No upper tray just a black plastic cover on the top in place of the tray.
My question is that how can I remove the dashpad in the mentioned case when I can't begin with removing the upper tray (can't see any screws). Maybe the plastic cover is removable or is it coming out with the whole dash? And what kind of equipment do I need when I begin removing the dash?
Thanks,
Attila
Quick Reply: i30 Stereo Removal
