Oil filter location
Anyone here a diy'er with oil changes? I plan to do my first one on this car but just can't find the filter. Can anyone point me to the location?
Thanks |
The filter is located on the passenger side of the car on the side of the engine that faces the radiator. #1 in the exploded picture below:
http://www.hmaservice.com/data/Passe...sfdem9007n.gif |
Thank you! It also looks like the sump is a two piece affair, the bottom piece being a black, stamped tin piece with the drain plug. Would this be true?
I don't want to end up draining the manual trans instead. Looks like I need to get a shop manual :-) |
There is a plastic cover you will need to remove to make it easy.
Thanks guys!
| All times are GMT -5. The time now is 08:25 AM. |
