Rear Combination Light Assembly
I want to replace a burned out stop light on my Elantra Touring (2010), but can’t get the “combination light assembly” off. I took out the 3 retaining screws, and don’t want to force/break the assembly. Any suggestions?
Thanks.
Ted
Thanks.
Ted
There are two prongs on the assembly that snap into the bodywork; one at the top of the assembly and one at about the mid-point. You have to work some type on thin tool between the assembly and the bodywork to disengage the prongs and release the assembly. Be careful or you'll chip the paint. Of course, the worthless owners manual failed to mention the clips, or for that matter, even the type of replacement stop light bulb! Like you, I was able to loosen the assembly but couldn't free it up without risking breaking the whole thing.
I finally had to go to a Hyundai dealership and get a couple of technicians to screw around with the thing until they figured it out. All this for a burned out bulb. Unbelievable!
Jim
Jim
Rear Combinatoin Light Assembly reply
Thanks for sharing your experience.
I thought it was me just not understanding what appeared to be a very easy way to replace the burnt out bulb. I may try gently prying out the assembly now that I know there are two clips. But like you I don't really want to chip the paint or break the unit - it looks expensive. So I may have to go to the dealer and spend the money to get the !@$@!$# bulb replaced.
Ted
Ted
I had the same issue with my '09 Touring stop light bulb replace. I used a wooden paint paddle normally used for mixing paint. By carefully inserting and prying the light assembly away at the top I gained enough clearance to insert a thicker wooden yard stick. More prying and I got the upper 'prong' disengaged from the body allowing to top of the light assembly to pull far enough away to remove the stop light bulb assembly. Not fun but doable.
Ray
Ray
uncle_stepa
03-06-2012 01:11 PM
