Remote keys i30
Where is the i30 forum? Does anyone else have an issue with only one remote key for i30?
RE: Remote keys i30
Hi rocket, have you tried http://www.i30ownersclub.com/forum/
lots of info there ;) |
Hi I am a qualified Lock smith what problems are you having? If you havn't had them solved them yet?
There are 3 parts for this type of key. Immobilizer - ( Communication chip inside the key that enables the motor to detect the correct key is being used). This will generally work without you knowing and thus work all the time. When it doesn't the car will not start. I.e Key will turn in iginiton, but may start and stop or just not crank. Remote - Sound pretty obvious, locks and unlocks your doors! Key/Blade - Also pretty obvious but the mechanical side of things. (When electronics fail, lol) Here is a basic diagonstic tree that i have found that may help you out.. (Please note this is for the remote only not key or immobilizer issues.) Troubleshooting1.Alarm does not work. (Hazard lamps work) http://www.hmaservice.com/data/Passe...scmbe6126l.gif 2.When hood is opened in ARM mode, burglar alarm does not work. http://www.hmaservice.com/data/Passe...sfdbe8401l.gif 3.When door is opened, burglar alarm does not work. (If tailgate and hood is opened, alarm works) http://www.hmaservice.com/data/Passe...shdbe6128l.gif 4.When tailgate is opened in ARM mode, burglar alarm does not work. http://www.hmaservice.com/data/Passe...shdbe6129l.gif 5.When the vehicle is locked by the transmitter, central door lock function works but hazard lamp doesn't blink. http://www.hmaservice.com/data/Passe...sfdbe8402l.gif 6.Central door lock function works, but keyless entry system does not work. http://www.hmaservice.com/data/Passe...sfdbe8403l.gif |
i have just got a 130 2007 i need a spare key and the locksmith said i need the key code from the agent went there and they refused to give it to me but they did offer to make me a spare at a price how can i find this key no it is not in my servise
pack will it be on the original ey than you |
| All times are GMT -5. The time now is 09:49 AM. |
