-   Hyundai Elantra Touring / i30 (https://www.hyundaiforum.com/forum/hyundai-elantra-touring-i30-45/)
-   -   tire pressure monitoring (https://www.hyundaiforum.com/forum/hyundai-elantra-touring-i30-45/tire-pressure-monitoring-7018/)
gunwaleman Aug 21, 2009 06:00 PM
make sure you do as the manual says and check your pressure. I was surprised to find my pressure off by about4 1/2 lbs per tire. I don't know what Hyundai means by significant pressure loss but to me that is significant. I usually do check it often but was relying on the monitor and I shouldn't have and as the manual says you shouldn't. My bad.
NovaResource Aug 21, 2009 07:10 PM
Tire pressures can fluctuate by as much as 5-psi depending on temperature. This is why you need to check your tire pressured regularly and not rely on the TPMS.
