-   Hyundai Entourage (https://www.hyundaiforum.com/forum/hyundai-entourage-43/)
-   -   Check engine light, ABS light, No cruise (https://www.hyundaiforum.com/forum/hyundai-entourage-43/check-engine-light-abs-light-no-cruise-9465/)
jordanwake Nov 1, 2010 02:48 PM
My entourage has the check engine light on as well as the abs light and the cruise does not work, I have a scanner and got code p0501 which is speed sensor issue , After doing some reading it seems all three problems could be related does anyone know where the sensor is located so I could have a look at it and see if it needs replacing
ITSYABOYJOSH Feb 6, 2011 08:13 AM
i would check the right front wheel speed sensor. it is mounted on the spindle. look for anything obvious. ie: unplugged connector, damaged harness...
