Horn Fuse
I have an issue with my 08' Entourage. Every time the horn is pressed with a good fuse, it pops the 15A fuse. I understand this is probably a ground issue but my question is does anyone have any advise to offer on how to solve this problem?
Guess I should have looked at the other post on this board and lack of replies, most are zero. Oh well, I tried at least.
Go to horn and take connector off.
Check the ohm reading on DVOM to the horn to see if it is shorted. Check other side of connector with volt reading on DVOM to see if there is power and grounds while pressing the horn Good luck |
