Power mirrors
07 Limited. The left outside mirror some times won't adjust, some times moves on it's own without the switch being touched. Is there a fuse that I can pull that will remove power to only the mirror system?
Does your Entourage have the memory for the seats and mirrors? I know the mirrors on my wifes 2006 Kia Sedona will stick sometimes.
The fuse for the outside mirrors is in the under dash fuse box (#2 below): https://www.hyundaitechinfo.com/data...sepbe6190n.gif It's the one labeled ACC but it's not exclusive to the mirrors. It also controls the radio, clock, RSE module and key interlock: https://www.hyundaitechinfo.com/data...sepbe6193n.gif https://www.hyundaitechinfo.com/data...sepbe6194n.gif Is your Entourage still under the 5-year bumper to bumper warranty? If it still is, have the dealership check it out. It may be a bad switch or motor. Have them replace it for free under warranty before it's over. |
Since that fuse controls other things, I think the best bet would be to unplug the wire in the mirror. Any idea how to get to the plug?
Personally, I think the best bet would be to let the dealer fix the problem under the 5y B2B warranty.
60,000 mile warranty on non drivetrain. Mine has more miles. Looking for procedure to get to the back of the switch or inside the mirrors.
I have the exact same problem also with a 2007. Did you find a way to disconnect the power from the mirror?
Originally Posted by sdhyundai
(Post 44690)
Ron |
If you have the memory mirrors - the mirrors will move when you put the car in reverse. This is by design and how they move changes with the setting of the mirror switch. Check the manual if this only happens when you put the car in reverse - it's a feature.
