Hyundai Forum Help & Suggestion Center Need help with HF? Ask! Have a suggestion to better HF? Tell us here..
Confused
Old 03-02-2018, 01:44 AM
ascott's Avatar
Exclamation Confused
Posts: 1 ConfusedI own a 2011 Hyundai Sonata, for the last 5 months I've been having problems with the car cranking up. I have to jump the car every time I cut it off. I'm confused between if it's my battery, my alternator, my starter or WHAT!!! If anybody else has had this problem please tell me what was it you did to fix the problem!
Old 03-02-2018, 06:53 PM
avisitor's Avatar
If you can crank and start the engine with a jump start ...
Well, it isn't your starter.
Do you have a multi-meter?
Digital Volt Ohm Meter?
Measure across the battery with the engine off
Reading should be about 12.5 volts
If the voltage is lower then the battery is suspect
If you can take it out
and to an auto parts store then ask to see if they can test it for free
Measure across the battery with the engine running
Reading should be about 14.5 volts
If the battery voltage is good
and the reading with the alternator working is lower than 14.5 volts
Then alternator is suspect
Ashiepooh
03-24-2011 11:18 AM
pdirico
12-23-2008 05:21 PM
Deggs1
11-03-2006 03:44 AM
graham7773
09-15-2006 11:12 AM
bluebaby
09-16-2005 03:10 PM
Quick Reply: Confused
