2.9L Deisel won't rev over 2800 RPM
I have been fighting this problem for 8 months. 1st I'll describe what happened and then what I have tried to fix it.
MY CAR: 2003 Hyundai Terracan 2.9L VIN KMHNM81XP3U092447 SYMPTOMS: I was driving up a fairly steep incline and accelerated through the last hairpin curve and everything was normal, no smoke When I got to level ground 200 meters later my car would not rev over 2700 RPM, smoke. Power band was 2200 - 2500 RPM but no turbo kick in. ATTEMPTED FIXES: Cleaned injectors and changed fuel filter Replaced timing belt Replace water pump Replaced mass airflow sensor Replaced high pressure fuel pump Replaced turbocharger Checked Acceleration Sensor & Actuator [3510042151] CURRENT CONDITION: Motor runs very smoothly and quietly Revs to 2800 RPM Power band 2100 - 2300 RPM Turbo does not kick in. Wallet is $2000 lighter Any ideas as to what is causing this? |
