Confused
Posts: 1https://www.hyundaiforum.com/forum/i...cons/icon4.gif ConfusedI own a 2011 Hyundai Sonata, for the last 5 months I've been having problems with the car cranking up. I have to jump the car every time I cut it off. I'm confused between if it's my battery, my alternator, my starter or WHAT!!! If anybody else has had this problem please tell me what was it you did to fix the problem! |
If you can crank and start the engine with a jump start ...
Well, it isn't your starter. Do you have a multi-meter? Digital Volt Ohm Meter? Measure across the battery with the engine off Reading should be about 12.5 volts If the voltage is lower then the battery is suspect If you can take it out and to an auto parts store then ask to see if they can test it for free Measure across the battery with the engine running Reading should be about 14.5 volts If the battery voltage is good and the reading with the alternator working is lower than 14.5 volts Then alternator is suspect If you can take it out and to an auto parts store then ask to see if they can test it for free |
