Hyundai Forum Help & Suggestion Center Need help with HF? Ask! Have a suggestion to better HF? Tell us here..
Starts but won't run
Old 06-24-2017, 01:56 PM
Tim S's Avatar
Default Starts but won't run
I have a 2002 Sonata GLS with the 2.7 engine.
I can start the engine and it runs for approx. 1 1/2 seconds.
Then it chokes & coughs and shuts down
I can start it again and again but it won't keep running
And it smells like gas after I start it a couple of times
Sure would appreciate ideas on this one
Tim
Old 06-25-2017, 12:04 AM
avisitor's Avatar
Try starting the engine with the throttle full open.
It sounds like the engine is being flooded.
Old 06-25-2017, 07:38 AM
Tim S's Avatar
Finally found the problem!
It was misfiring back up through the intake manifold because of a bad gasket in between the manifold and block. A portion folded and I had a leak.
Taking it to work today!!
Thanks for your input
Old 06-25-2017, 10:02 PM
avisitor's Avatar
Thanks for the update.
Sounds like very useful information
cgd
09-11-2021 02:17 AM
stan2121
06-26-2017 03:24 PM
Dolomoto
12-31-2016 08:14 PM
jakeg
01-12-2013 10:03 PM
richie
10-03-2007 01:38 PM
Quick Reply: Starts but won't run
