Hyundai Forum Help & Suggestion Center Need help with HF? Ask! Have a suggestion to better HF? Tell us here..
Hyundai i40 ignition and key problem
Old 06-02-2019, 01:33 PM
Default Hyundai i40 ignition and key problem
Can anyone advice please? key in ignition wont turn either way, tried wiggling it and spraying it nothing. Can't move car and it has electronic handbrake. Suggestions please as should be going away Thurs and need the car for towing!
Old 06-02-2019, 02:27 PM
You may have already done this, but need to ask.
Did you try turning the steering wheel hard against the stop in one direction or the other and holding it there while trying to turn the key ? Sometimes pressure against the steering wheel when parked will prevent you from being able to turn the ign key.
Old 06-02-2019, 04:15 PM
Yes tried that and no luck
Old 06-02-2019, 05:56 PM
Can you move gear selector out of park and then back in?
Then jack up front end of vehicle to see if that releases key?
Old 06-03-2019, 12:37 AM
[QUOTE=avisitor;56233]Can you move gear selector out of park and then back in?
Then jack up front end of vehicle to see if that releases key?[/QUOTE
No and its an electonic handbrake so going nowhere!!
Old 06-03-2019, 01:25 PM
What has the electronic hand brake got to do with it?
You should still be able to shift the gear selector?
And jacking up the front wheels should release the steering wheel to help release the key
If none of that works then the key is stuck in the cylinder
Taking a small hammer and tapping the key might release the key
But, in any case, the lock needs to be replaced
tgawron
08-04-2018 07:29 AM
hyundaivirgin
04-11-2011 12:52 PM
b5106
03-12-2011 01:18 AM
NovaResource
02-23-2011 08:14 PM
Quick Reply: Hyundai i40 ignition and key problem
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
