valve stem - 2017 Sinata
The majority of the time the stem is part of the sensor. Some older sensors were mounted to the center of the wheel rim.
If it is leaking out the opening where the air goes in, a simple valve cap/tool can tighten the core if it is loose, otherwise it may need to be replaced.
Use only plastic valve caps to prevent corrosion from dissimilar metals.
nufo
01-30-2017 10:45 PM
