2010 2.0T genesis coupe stalling
Hi guys, I have a 2010 Genesis coupe and almost every day it does not start at some point. Some times it just does not start and some times it starts but then within 10/20sec the revs drop and it stalls.
ODB reports p605 and p2105 error together but clears the CIM light by itself after a day or so. There is a tech bulletin out which says to replace the ECM module but I am not sure that this is the right fix. Mode 6 data shows that a misfire did occur on cylinder 4 and another time it was captured on cylinder 1. I am suspicious that the evap monitor 0.090" is at -1432 and the max value is -1400 which makes me wonder if I have an evap problem. Any suggestions to narrow the fault down? |
The problem can possibly be either a dirty fuel filter or a faulty O2 sensor. Have those inspected.
You need an ECM update
Needs to be done by the dealer Believe there is a TSB (technical service bulletin) on this When a P2105 occurs with a P0605 Was was for a Sonata?? Check with your dealer |
2011 genesis coupe 2.0t
I have a 2011 genesis coupe 2.0t that has a P0016 Code and doesn’t start up idk what the problem is anybody know what it is |
