2011 Genesis Transmission Fluid Change
I have this sedan 3.8L Genesis, 120,000 miles. Great car so far.
It seems to have a sealed transmission. I don't know if the previous owner ever had the fluid changed, so I am thinking I would have it done. My question is: Is this something I can do myself (I'm very handy with a wrench)? Should I? Or, can any mechanic shop do this or should I go to a dealership? If I do it myself, what do I need to be concerned about? Is there a filter that should also be changed? Should I drop the pan? Should I drain and fill all the fluid or half of it. Thanks for any help. |
Not knowing past maintenance history, you could run into some problems.
I would suggest you consider having the dealership do the first change and once that works out OK, you might consider doing the next one. |
Thanks. I was leaning that way. I just never liked dealerships.
Thanks for sharing this helpful guide on changing the transmission fluid for the 2011 Genesis! Proper maintenance is key to keeping our cars running smoothly. By the way, if you're looking for a side gig as a driver, you might want to check out the opportunities at https://praca-kierowca.pro/praca-kierowc%C4%85-uber . It could be a great way to make some extra cash with your well-maintained Genesis!
| All times are GMT -5. The time now is 02:08 AM. |
