2006 Getz
I have no central locking, radio or interior light.
This started after I disconnected the radio and saw a spark. Checked all fuses under dash and bonnet all appear ok. |
Have seen this before
Does the engine start? Do the head lights turn on? Check or recheck all the fuses under the dash. There is a common fuse that all three use. Also, does the central locking work when the engine is running?? |
I will check if door central locking works with engine on when daughter gets home from work. Other than radio, central locking and interior light everything else is fine.
