aircon cranking sound
Hi,
I am driving a new 1.3L getz..i've gone thru the run-in period..recently i experience some cranking sound whenever i start the engine and turn on the aircon..it happens only during morning startup..Is tis normal??..any advise from some expertise out there? [sm=dontgetit.gif] |
RE: aircon cranking sound
ok the noise you are hearing could well be the a/c compressor clutch engaging if it is too noisy then this should be replaced under warranty,.
