Which fuse?
Hi, I have a 2011 2 Door RHD Getz, and the lights behind the fan dial/heat level dial etc have stopped working. Can anyone please give me a clue as to which fuse I can change first? I'm a bit confused by it, to be honest.
If,,,,,,,,you have a copy of your owner's manual, there should be a diagram in there with an explanation of which fuse protects what.
If you check all the fuses and none are questionable, you may need to verify power is getting out of the dash dimmer switch to the dash lamps. |
For your 2011 RHD Getz, check the interior fuse box. Look for the fuse related to instrument panel lights, usually labeled "I/P ILL" or similar. Consult your vehicle's manual for the precise location and fuse number. If the fuse appears intact, inspect the bulbs behind the fan/heat dials for potential issues.
| All times are GMT -5. The time now is 01:44 AM. |
