Getz hesitates on take off
Hi guys, I have a 2008 1.6 petrol Getz, great car but a few minor problems.
On take off it stutters a little at very low revs as you first let the clutch out, like a dodgy plug or lead. Otherwise runs absolutely perfect. I have put new plugs in and checked the resistance of the leads. Cant work out though, it means in the manual by BOUG and R16AIPS? resistance seems close to spec, looks like new NGK silicone leads on there. Any other suggestions for stuff to check? Its just a little annoying because my daughter is learning to drive in it and its harder to take off than it should be |
A couple of bottles of fuel injector cleaner
any reason?
I would think if it was a dodgy injector it would be affecting it in other ways also |
Sticky injectors are slow to react to throttle
A bad TPS sensor would do the same hesitation Cleaning out the throttle plate and intake plenum is a good place to start But as you know, I can not see your engine so these are only guesses. |
