Help! Oil/fluid leak
2003 Hyundai Getz 1.5L GL 3dr
Hi, I have been trying to figure out where my oil/fluid leak is coming from. Jacked the car up and searched. I may have found where it's leaking, I'm just not sure if it's correct or what's the part name of it. Hopefully someone can help. Located at the back of the engine, above the started motor. |
Found it, solved it. :)
Leak was coming from Drive Shaft, Oil seal looked like it was damaged. Replaced it with a new one and no more leaks. |
Thanks for the update.
