Correct Timing belt kit code
I am getting a lot of problem to found the correct timing belt and seal kit for a matrix 1.8 2002 gasoline.
some seller gave me belt with incorrect number of theet:113 and incorrect diameter of seal. do you know how get the correct code of auto parts.? Thanks in advance regards Rodrigo |
If you have a dealership around ,you should be able to get the correct parts.
If not,you might still be able to get the part numbers from a dealer and cross them over to where you are purchasing a replacement. |
