P2125 04 santa fe 3.5
Old 03-15-2009, 10:03 AM
rsudano's Avatar
Default P2125 04 santa fe 3.5
My check engine light came on so I used an OBDII checker and it said code P2125 throttle/pedal position sensor. I 'm not sure what to do about it . do they mean the TPS or APS? What do these parts cost? And could it be something else?
Old 03-15-2009, 01:32 PM
The throttle position sensor (TPS) needs to be replaced. Take it to a mechanic and have it replaced. If the car is still under warranty, go to the dealer and have it fixed for free.
Old 03-15-2009, 10:44 PM
rsudano's Avatar
Default please explain
Thank you for answering. Can you please explain why the TPS needs replaced and not the APS? I just found that the hmaservice website states that A p2125 code is an accelerator position sensor(aps#2 main) property malfunction. What am I missing here? Please help. I don't want to be nickeled and dime by ambiguous semantics.
Old 03-15-2009, 11:13 PM
ken99's Avatar
Here's a thread discussing a similar problem:
https://www.hyundaiforum.com/forum/s...ead.php?t=5207
The TPS and APS serve separate but related purposes in the Electronic Throttle System or ETS. Yes, it could involve an APS replacement.
Old 03-16-2009, 06:00 PM
rsudano's Avatar
I replaced the APS and cleared the code. Drove about 30 miles and the check engine light did not come back on. It accelerates from a stop a little better but is still very sluggish going up hills. I don't know what else to do with it.
