2005 sante fe 3.5l
Old 03-17-2017, 02:13 PM
Danielspencer's Avatar
Default 2005 sante fe 3.5l
My car is sluggish turning over and won't start battery is fully charged where do I start looking for solutions?
Old 03-18-2017, 12:12 PM
avisitor's Avatar
Look at the starter.
Sluggish turning over is a sign that either the starter is faulty
or something is binding which is preventing the starter from turning over properly.
or corrosion is preventing the starter from getting the power it needs to turn over the engine
What to do?
Check charge on battery
Check terminals and wires for corrosion.
Corrosion builds resistance and eats up the power needed by the starter
Have assistant turn the key to start and
you take something and tap the starter to see if that helps to crank over the engine
Loosen up the accessory belts and check each pulley for binding
Note: It is also possible that a clogged exhaust will make it difficult to start an engine
timlewis7
01-17-2012 07:29 AM
lizcvt
08-12-2010 10:28 AM
srcbeast
09-10-2007 01:12 AM
left90
09-01-2005 02:06 PM
shiva
09-26-2004 03:30 AM
Quick Reply: 2005 sante fe 3.5l
