04 sanat fe not starting or turning off
i have an 04 santa fe 4wd 2.7 and lately ive been having problems with the car not wanting to start after i put gas in it so i changed the fuel pump and strainer and the plugs and i still have the problem is there an in line fuel filter somewhere? also the car does not like to shut off, i can take the key out and everything and it will continue to run until i turn the key off and on a couple times are these related at all? any ideas id be happy to hear them
Your fuel filter is that unit that the nose of the fuel filter plugged into, nose of fuel filter had the black rubber piece on it that slid into the fuel filter...
All that stuff (pump & filter) is in the pump module you had in your hands.
Sounds like you also have an electrical concern too..
baurebu
Nov 12, 2012 09:54 AM
travelbeastfilm
Dec 18, 2011 07:28 PM
