07 sf. Engine fault.
I just got an engine fault. Car started to sputter and run rough. I think its the tps but can find the part. These are the codes.
Got a code reader. Fault codes are..... p1295 said the code could not be found. p2135 throttle/position sensor/switch a/b voltage correlation. p0638 throttle actuator control range/performance bank 1. p2106 throttle actuator control system. Force limited power. |
