2001 hyundai sante fe timing belt problems
Hello all, my timing belts broke on my 2001 Hyundai Sante Fe. Also replaced the serpentine belt and the crankshaft position sensor was burnt up so I replaced it. We have made sure all the timing marks are in line but my veh still will not start. It cranks and cranks and it is getting fire and gas to plugs but just won't start. I would really appreciate any ideas you have. Thank You
Did your timing belt break while the engine was running? If it did, all (or most) of your valves are bent or broken. This is why you replace the timing belt every 60k miles or 5 years.
https://www.hyundaiforum.com/forum/s...ad.php?p=20637 |
