2001 Santa Fe 2.4l Manual transmission oil change
Old Sep 27, 2010 | 12:43 PM
AndyFe's Avatar
Default 2001 Santa Fe 2.4l Manual transmission oil change
Hello, picked up a reasonable 2ndhand 2001, changed every fluid (diffs, engine etc.) but can't find the fill for the manual transmission, any help appreciated.
Is it that bolt on the second pic on the transmission casing. Hey a pointer as to where the drain plug would be nice.
It's a good car but I've a feeling there's something not quite right. When driving I dip the clutch to change up a gear, foot off the gas but the revs momentarily rise. Also on tick-over i blip the gas the rev rise quickly but die down slowly. I've cleaned the throttle, MAF, IAC etc.
cheers and thanks in advance
Andy
Old Sep 27, 2010 | 02:21 PM
Hit the Hyundai dealer for 3 qt of 08950-00020 oil... DONT USE 80/90 GL5 !!
Old Sep 27, 2010 | 02:26 PM
AndyFe's Avatar
Thanks for the advice, I've just bought 75W/90 GL-5 as is mentioned in the owners manual. I can return it, is that number you provided a Hyundai part-number?
Ah right, Google turned it up, I'll take that advice if it's not too much more costly.
Cheers
Andy
Old Sep 27, 2010 | 02:53 PM
75/90 /// 80/90 GL5 is reserved for the transfer case and rear axle out back..
The GL4 stuff is hard to find on open market, best to use the number I give you and keep from killing the brass rings inside the gearbox.
The Hyundai oil is approx $16/qt... number may be valid at Kia if closer to you.
Brain
Nov 21, 2009 09:45 AM
thx1971
Apr 8, 2009 08:35 AM
anonymouse
Oct 13, 2008 07:11 PM
rip
Sep 4, 2006 11:43 AM
rip
Sep 4, 2006 11:42 AM
